paradise12870
#1 Posted : Tuesday, February 8, 2011 2:21:54 PM(UTC)
paradise12870
I have an ice maker outside that has either a crack hose or valve from being frozen. What I am trying to determine is how I can use the existing valve with new hoses. In talking to the parts person, he indicated the hose slide on and grip. What he couldn't tell me if they could be taken off and reconnected to valve. Any one who could help me with this question/
Joe / APP Team
#2 Posted : Wednesday, February 9, 2011 1:31:48 PM(UTC)
Joe / APP Team
Paradise,
I understand, the unit froze up, but I don't quite understand what you have in mind,
If this unit had frozen water in the supply tubing or the internal tubing, you need to be replacing evrything, all the tubes, and the fill valve, just for safety's sake at least.
Part number: AP4362516
The fill have does have "John Guess" fittings, those fittings are basically a compression fit and dont have nuts or ferrels.
And the water tubing kit has metal inserts,and any connector nuts or ferrels can be re used, unless there are obvious cracks,or breaks.
Part number: AP4507736
Part number: AP4507674
Part number: AP3108446
And if you left water sitting in the reservoir, you'd also need to consider the pumps,
Part number: AP3959570
Part number: AP3965359
These are the parts I would have on hand, just in case.
Kitcheaid Stand Alone Ice Maker in Clean Mode (Refrigerator & Freezer Repair)
by gundoc 11/4/2011 3:41:20 AM(UTC)
Kitchen aid stand alone ice maker (Refrigerator & Freezer Repair)
by A Leasure 9/1/2010 10:14:10 AM(UTC)
Kitchenaid stand alone ice maker (Refrigerator & Freezer Repair)
by DAMON ROY 5/11/2010 2:20:40 PM(UTC)
kitchenaid stand alone ice maker not working (Refrigerator & Freezer Repair)
by DAMON ROY 5/7/2010 1:27:21 PM(UTC)
Stand alone ice maker (Refrigerator & Freezer Repair)
by BKTYLTX 4/6/2010 7:41:51 AM(UTC)
KitchenAid Stand Alone Ice Maker - cleaning light flashes - won't make ice (Refrigerator & Freezer Repair)
by bchristal 11/12/2008 2:46:04 PM(UTC)
stand alone ice maker wont stop filling water reservoir (Refrigerator & Freezer Repair)
by hotttoddie 9/22/2008 9:20:22 PM(UTC)
Request help for Kitchenaid stand alone ice maker (Refrigerator & Freezer Repair)
by ran007 6/29/2008 6:39:04 AM(UTC)
