Evan
#1 Posted : Monday, September 15, 2008 1:35:55 PM(UTC)
Evan
Superba washer stops in mid cycle. Usually finishes wash cycle then stops but not always at the same point in the complete cycle. I would guess it would be a timer problem but would like toknow if it is likly to be anything else? Thanks Evan
abbie
#2 Posted : Monday, September 15, 2008 1:56:07 PM(UTC)
abbie
It does sound like the timer.But to be on the safe side make sure your both tap valves to your hoses are open,because if one is closed let,s say cold, and the rinse is set on cold then the timer will stop half way in the cycle..
Evan
#3 Posted : Monday, September 15, 2008 2:55:14 PM(UTC)
Evan
thanks, I checked and both the hot and cold are working.
libertyappl
#4 Posted : Monday, September 15, 2008 6:34:59 PM(UTC)
libertyappl
If it's stopping at different times I have a few other questions?
Does the timer advance after the washer stops?
Or after it stops can you continue the cycle from that point after a period of time?
Will the washer complete a cycle with a small load w/o clothes?
Nat
Evan
#5 Posted : Friday, September 19, 2008 1:46:10 PM(UTC)
Evan
Nat. Thanks for your reply.
Sometime the timer advances later and sometimes not.
Usually after a period of time you can advance the timer and complete the cycle.
The size of the load doesn't seem to make any difference.
Thanks for your help, Evan
libertyappl
#6 Posted : Friday, September 19, 2008 1:56:20 PM(UTC)
libertyappl
Evan
See if you can see how many amps the washer is drawing thru the cycle. Sounds like the motor is overheating.
Does it still feed power to the motor after the unit stops in mid cycle?
Nat
Washer stops mid cycle (Washer Repair)
by NevadaBill 7/3/2017 7:54:11 AM(UTC)
washer stops mid cycle (Washer Repair)
by postal13 4/18/2016 4:38:15 PM(UTC)
GE washer stops mid cycle (Washer Repair)
by APPLIANCEDUDE1972 3/4/2015 6:32:45 AM(UTC)
Dishwasher stops mid cycle (Dishwasher Repair)
by vpchianese 11/15/2013 2:32:24 PM(UTC)
Maytag washer stops mid cycle (Washer Repair)
by paubert03 12/2/2012 3:33:21 PM(UTC)
by dideyjohn 11/27/2012 6:06:54 PM(UTC)
by tedwards353 2/20/2012 10:21:16 AM(UTC)
by maryprice4 10/17/2011 6:29:09 PM(UTC)
by ncdunn 3/31/2011 6:55:03 PM(UTC)
by krislinda 11/9/2010 12:52:34 PM(UTC)
Whirlpool Washer Stops Mid Cycle (Washer Repair)
by cfphillips 9/3/2010 11:01:15 AM(UTC)
by Dave W. 6/7/2010 10:59:53 AM(UTC)
Maytag SE 1000 washer stops mid cycle or won't start wash cycle (Washer Repair)
by katyat 9/10/2009 1:23:57 PM(UTC)
by CLK 7/19/2009 11:03:25 PM(UTC)
Frigidaire diswasher stops mid cycle (Dishwasher Repair)
by bhacker 7/17/2009 3:58:44 AM(UTC)
