2 Pages12>
Tony Wang
#1 Posted : Tuesday, February 1, 2011 2:49:59 PM(UTC)
Tony Wang
Hi!
I have GE Profile gas cooktop need to replace switch. The model #: JGP336WED1WW.
I noticed that glass and burner box are together in one piece, and I don't know how to open the glass.
Can you provide me the instruction to open the glass and put it back after I fix?
Is it adhesive or other locking?
Thank you!
-Tony
Joe / APP Team
#2 Posted : Wednesday, February 2, 2011 12:47:28 PM(UTC)
Joe / APP Team
Originally Posted by: Tony Wang Go to Quoted Post
Hi!
Thank you!
-Tony
Tony,
Presuming the cooktop is properly installed,
Unplug the power cord / turn off the power to the cooktop.
Remove the burner valve knobs, grates and burner caps.
Remove the two screws holding the burner base to the drip bowl on all the burners
(make sure you label the location of the burner base, caps , bowls, and wires ,you will need a putty knife, as well)
Remove the drip bowl assemblies(if they are stuck to the glass,use the putty knife) disconnect the igniter wire(s) from the porcelain igniter electrode.
With a putty knife(or simillar tool) CAREFULLY insert the tool between the glass and the metal burner box frame, to release the foam seal tape, and slowly, carefully lift up on the glass panel.
Perform the repair and reverse the procedure, and test the unit.
In addition to the part(s) you have, you'll also need the following seals,
Glass to countertop seal
Part number: AP2634968
Glass to burner box frame seal
Part number: AP2016094
Tony Wang
#3 Posted : Thursday, February 3, 2011 9:15:08 AM(UTC)
Tony Wang
Hi! Joe,
Thank you so much for your reply with detail instruction!
I'll give it try and let you know results.
-Tony
Joe / APP Team
#4 Posted : Thursday, February 3, 2011 10:11:02 AM(UTC)
Joe / APP Team
Hi! Joe,
-Tony
Tony,
Great ,
Just be careful with the glass, it's temperred glass, and you never know.
Will keep an eye out for your next post.
:cool: :cool: :cool:
drhadeen
#5 Posted : Wednesday, April 20, 2011 9:23:19 AM(UTC)
drhadeen
Joe, I received the replacement part, but it comes with the full metal suround. I have taken out the old cracked assembly and it looks like I have to undo the electonics. I have gotten all the clips/screws holding down the heating elements, but I can't seem to get the little beige electonic box out of it's place so that I can move all the heating elements to the new top. It's plastic and I want to proceed with caution - any hints?
Tanks
Figured it out
Joe / APP Team
#6 Posted : Wednesday, April 20, 2011 10:09:24 AM(UTC)
Joe / APP Team
Tanks
Figured it out
Great job,
So you're up and running, It wasn't really that hard, it just sounded bad.
Good Luck,
Thank You,
drhadeen
#7 Posted : Wednesday, April 20, 2011 10:20:39 AM(UTC)
drhadeen
not quite yet. When I put the unit back together, the front panel is not fitting as tight as it should. It kind of pops up. I thought I followed the screw pattern correctly, but not sure what to do next. I have yet turned on the power to the unit.
Thoughts?
the job is done - and it works! I am proud of myself!
Joe / APP Team
#8 Posted : Wednesday, April 20, 2011 1:13:30 PM(UTC)
Joe / APP Team
Thoughts?
What did you find on the control panel alignment.
Great , and of course it works, you should be proud of yourself.
You're welcome,
It was my pleasure to assist.
:D :D :D
drhadeen
#9 Posted : Wednesday, April 20, 2011 1:15:44 PM(UTC)
drhadeen
I had not attached the screws correctly. Just needed to make sure they were threaded into the correct area. Thanks again.
Joe / APP Team
#10 Posted : Wednesday, April 20, 2011 1:20:05 PM(UTC)
Joe / APP Team
Good deal,
Nothing major, thank goodness.
:D :D :D
Guest (9)
2 Pages12>
