2 Pages<12
#11 Posted : Monday, January 31, 2011 2:14:26 PM(UTC)
Check how the chopper engages the pump impeller.
You also may have a clog going to the upper spray arm.
If this is not the issue then very likely the pump itself is the culprit.
- The chopper assembly Part number: AP3039186
- The pump & motor assembly Part number: AP3179651
KenmoreDishwasher
#12 Posted : Monday, January 31, 2011 2:20:09 PM(UTC)
KenmoreDishwasher
Gene,
What do you mean by "Check how the chopper engages the pump impeller"? Also, did the amount of water in the bottom of the dishwasher sound right?
#13 Posted : Monday, January 31, 2011 2:26:21 PM(UTC)
You should feel some tension when you turn the chopper manually. I believe CCW.
It sounds good but you can dump an extra gallon to see how if it works.
2 Pages<12
