hcsilva
#1 Posted : Sunday, September 14, 2008 11:22:27 AM(UTC)
hcsilva
HI,
am trying to get my sears kenmore 90 series, gas, model number is scraped off, to start up. Had about a foot of water the basement. Had water in the drum. Should I check the burner and make sure that section is clean. Everytime I try to start the dryer, it just goes "trump". Drum turn bat hand, the door switch is working. Is the motor just wet? and needs to dry?
Thanks for any assistance.
libertyappl
#2 Posted : Sunday, September 14, 2008 1:15:41 PM(UTC)
libertyappl
If the motor was wet when you tried to start the dryer chances are it shorted out.
hcsilva
#3 Posted : Sunday, September 14, 2008 6:13:35 PM(UTC)
hcsilva
How would I determine if the motor is storted?
libertyappl
#4 Posted : Sunday, September 14, 2008 7:58:17 PM(UTC)
libertyappl
I would not recommending this unit. If possible claim it on insurance and get it replaced.
nat
#5 Posted : Monday, September 15, 2008 1:59:26 AM(UTC)
I would pull the motor out and bake in a oven at 200 degrees for a few hours, then put 115 volts to pins 4&5 and see if it now runs, but you may have ruined the motor by using the dryer.
hcsilva
#6 Posted : Tuesday, September 16, 2008 6:29:33 AM(UTC)
hcsilva
I'll pull it tonight.
hcsilva
#7 Posted : Tuesday, September 16, 2008 6:33:31 PM(UTC)
hcsilva
Well, still digging, Stop at blower. Trying to figureout if I need to pull the drum? The serial number of this Kenmore is MH4705935.
Is it worth it? libertyappl says "take it out." Any Suggestions???
Guest (4)
Final rinse never stopped - flooded basement. (Washer Repair)
by Ted Barry 12/9/2011 5:36:42 AM(UTC)
Flooded Basement (Refrigerator & Freezer Repair)
by jppwrs 9/15/2011 10:40:52 AM(UTC)
