No error codes, ever. My husband has the cover on the back off, is there something we should look for?
Look at all the connections make sure they are tight and no corrosion of any kind. A regular pencil eraser works good for cleaning contacts. Natalie
Everything looks like new back there, he looked at the connections and used an eraser. But it still won't stay on.
I would have to say it's the control board/clock is the problem, everythng on the wiring diagram runs thru there. If you can check the wires going to the ignitor and valve as well might be a good idea. A(Don't touch the ceramic part of the ignitor with bare hands, oil from your fingers will mess it up) Nat
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: 99556 Was thanked: 4 time(s) in 4 post(s)
My accubake is the same way. New igniter?
