It may not be cheaper to buy a whole IM byt it is usually a lot faster. Nat ps I had to go to my sons football game last night too.:)
hey nat did you get my reply on th i m john
nat the whole i m has the emiter boards and thermostat built in
the complete IM usually has all that you need! Makes it fast & easy to repair. Nat
nat the price from sears for the board is $81.99 and for the thermostat its $29.89 and for the whole i m from sears is $154.99 and from my local appliance parts warehouse the whole i m is $125.00 i think ill get the whole thing and it a whirpool part thanks for all your help john
You're welcome.....did you happen to check on the price from this site. They are cheaper on parts that anyone else, that doesn't sell wholesale anyway. I looked at your model again and the emitter board are not included. Nat
nat i found the part on your site but its out of stock and there not sure when youll get more my wharehouse is just up the a couple of miles thanks again i hope it works lol john
What is the part number for the IM? Nat
hey nat well i installed the new unit and it fills with water and thats it the old one had a broken piece on the motor and emiter board it worked a couple of times and quit when i open the door the led flashes when i close the little door on the left it goes to solid red and when i turn the light switch off it goes out completely any ideas john
nat btw the 628519 part # is the new and improved module unit john
