2 Pages<12
Drags1998
#11 Posted : Saturday, September 13, 2008 5:36:02 AM(UTC)
Drags1998
Respectfully Nat, YOU are INCORRECT!!!!! In order to remove the front panel on a MAYTAG A613 you HAVE to remove 2 screws at the BOTTOM FRONT and pull the panel OUT at the BOTTOM, it will UNLATCH from the top!!!After the FRONT panel is removed!!! THEN and ONLY THEN you can remove the 3/8 headed bolts(1 in each front corner of the TOP) and lift the TOP!!!! Thanks for your help!!!!
libertyappl
#12 Posted : Saturday, September 13, 2008 6:41:55 AM(UTC)
libertyappl
I stand corrected If I made any error in description. But I do try to help as many people as I possibly can in while I'm on line I I do so without being crass or rude.
Thank you for your input.
Nat
Drags1998
#13 Posted : Saturday, September 13, 2008 6:58:14 AM(UTC)
Drags1998
And YOU do a GREAT JOB!!!! I could just see them DRIVING a CROWBAR in there to lift the top.LOL!!!!!!!:eek: Keep up the good work!!!!!
2 Pages<12
