I have a problem with my Maytag gas dryer model # mcg8000aww, it gets hot when it first comes on in the sensor dry mode but then the gas cuts off after about a minute and it just blows cold air. If it is on the timer mode, the gas will not come on at all.
:) the vents are all clear and air is moving fine, I don't know if I should change the flame sensor, fuse, or coils. Tim Originally Posted by: kayakcrzy
Ok, I will say again. Replace the coils on the gas valve. The secondary coil is bad on the gas valve. By the way you are explaining, you are saying it comes on for a minutes, and heats, then the gas shuts off, and then never comes back on. That is the coil!!!!!!!!!!!!!!!!!!!!! Tom ApplianceEducator.com
:) :) :) thanks I appreciate the clarification!!!!!!!!!!!!!!!!!!!!!! Tim Originally Posted by: kayakcrzy  Ok, I will say again. Replace the coils on the gas valve. The secondary coil is bad on the gas valve. By the way you are explaining, you are saying it comes on for a minutes, and heats, then the gas shuts off, and then never comes back on. That is the coil!!!!!!!!!!!!!!!!!!!!! Tom ApplianceEducator.com
:) :) :) Thanks alot, dryer works great now! Tim Originally Posted by: kayakcrzy
Great Job!! Glad to help!!!! Tom www. Applianceeducator.com
