My friend was cleaning the bottom of my fridge. I underand that the compressor is underneath. Now my family is smelling something that I imagine freon would smell like. A chemical smell when we open the doors. Could it b harmful? It seems to be cooling fine, for now.... Help!
Someone please reply to my funky monkey smell post! I need some advice, bad!
Originally Posted by: msnancy  Someone please reply to my funky monkey smell post! I need some advice, bad! Ms Nancy, It's not a freon, chemical leak, your fridge would have quit cooling, if it was. Is the odor in the freezer compartment as well ? Did you use a chemical cleaner to clean the inside liners ? When you get the time, you might want to try, Washing everything, including the shelves and bins on the door, with HOT soapy water, and rinse several times. Take a coffee cup saucer and set it on at least one of the middle shelve, and put a couple of ounces of coffee, vanilla extract, or a small box of baking soda(you could also use a frabric softner sheet). Give it a couple of days and the odor should be acceptable. :cool: :cool: :cool:
