GPZSTEVE
#1 Posted : Friday, September 12, 2008 8:55:18 AM(UTC)
GPZSTEVE
my fridge worked fine until i turned the temp down for my freezer, ever since, my fridge varies from 32 - 56 degrees and this happens about every 4 days. I turned my freezer back up but still fridge is unstable.
GPZSTEVE
libertyappl
#2 Posted : Friday, September 12, 2008 8:57:06 AM(UTC)
libertyappl
Check for a defrost problem, frost in the back of the freezer.
Nat
GPZSTEVE
#3 Posted : Sunday, September 14, 2008 6:06:20 AM(UTC)
GPZSTEVE
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
GPZSTEVE
#4 Posted : Sunday, September 14, 2008 6:09:35 AM(UTC)
GPZSTEVE
i do have some frost on the back side of freezer
libertyappl
#5 Posted : Sunday, September 14, 2008 8:25:16 AM(UTC)
libertyappl
Sounds like you are having a defrost problem, if your model has a defrost timer advance it unitl the unit turns off and remove the rear panel in the freezer and look at the heater element see if it is on, test the defrost thermostat while it's cold. Post your results and wecan figure out which part(s) you may need.
Nat
GPZSTEVE
#6 Posted : Friday, September 19, 2008 7:39:20 AM(UTC)
GPZSTEVE
Im Not Sure How To Test The Heater Element The Fan Is Working Though
libertyappl
#7 Posted : Friday, September 19, 2008 8:00:59 AM(UTC)
libertyappl
Due to the type of heater you have(which this type rarely fails) I wuld say test the defrost thermostat, located by the evaporator coils with an ohm meter it has to be cold to test. If it's not the thermostat it's probably your adaptive defrost control.
Nat
GPZSTEVE
#8 Posted : Saturday, September 20, 2008 4:39:19 PM(UTC)
GPZSTEVE
I have already replaced the aadaptive defrost unit and the fridege wont cool below 37 degrees i have it turned sll the way up
libertyappl
#9 Posted : Saturday, September 20, 2008 6:38:26 PM(UTC)
libertyappl
Test your defrost thermostat (aka bi-metal)
nat
silver eagle
#10 Posted : Sunday, September 21, 2008 2:02:40 PM(UTC)
silver eagle
make sure the cold air inlet into the frig is not iced over. Inside the freezer part at the top right is a small plastic cover. remove cover to check if passage into frig is open. Good luck.
Guest (6)
