thermador double oven model scd320tb lower oven does not work have replaced lower oven board and bake element and the oven still does not function,what am I failing to analyze correctly . Thank you
Here are your parts Replacement parts for scd302tb models | AppliancePartsPros.comI am assuming everything looks normal just no heat. Getting tech info on Thermadors is difficult so the following is a bit of a guess. If you look at Section 4 Item 12 they show a thermostat (may even be a fuse). In their description it is a high temp cut-out, odds are this is open. |
THIS FORUM IS DEAD!!!!!!! |
Thank you the problem with the thermador double oven was the lower high temp cut out,fuse replaced it-worksfine bobgto
