bobgto
#1 Posted : Wednesday, January 5, 2011 1:04:46 PM(UTC)
bobgto
thermador double oven model scd320tb lower oven does not work have replaced lower oven board and bake element and the oven still does not function,what am I failing to analyze correctly . Thank you
#2 Posted : Thursday, January 6, 2011 2:58:26 AM(UTC)
Replacement parts for scd302tb models | AppliancePartsPros.com
I am assuming everything looks normal just no heat.
Getting tech info on Thermadors is difficult so the following is a bit of a guess.
If you look at Section 4 Item 12 they show a thermostat (may even be a fuse).
In their description it is a high temp cut-out, odds are this is open.
bobgto
#3 Posted : Monday, January 24, 2011 10:05:20 AM(UTC)
bobgto
Thank you the problem with the thermador double oven was the lower high temp cut out,fuse replaced it-worksfine bobgto
