tshug
#1 Posted : Sunday, March 15, 2009 6:20:18 AM(UTC)
tshug
My dryer is not producing any heat. It tumbles fine, but with just cold air. I'm trying to locate where the thermal heat sensors or fuses are located on the unit.
#2 Posted : Sunday, March 15, 2009 6:38:58 AM(UTC)
Here are your parts, includes a wiring diagram
Replacement parts for FRG FEX831CS0 | AppliancePartsPros.com
This should help you in replacing it if it is blown
http://www.frigidaire.com/tip/s...t/Laundry/5995381885.pdf
The fuse is Item 36 in the "Upper cabinet/drum/heater" section.
Note it is listed as KF36 at the bottom of the page.
This fuse will prevent the dryer from tumbling so is not your problem.
Most likely the heater is blown or a thermostat is open.
I would suggest you purchase a meter. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
Drags1998
#3 Posted : Sunday, March 15, 2009 6:45:16 AM(UTC)
Drags1998
CHECK your circut breaker in the Home!!!!!!!
tshug
#4 Posted : Sunday, March 15, 2009 3:41:50 PM(UTC)
tshug
Thanks denman...I'll check out ther parts list. I've repalced the thermal sensor on my Whirlpool in the past, but after taken the covers off my Frigidaire stackable I'm still not sure where to locate it.
Drags1998
#5 Posted : Sunday, March 15, 2009 4:29:23 PM(UTC)
Drags1998
tshug, Have you checked the breakers in the home yet? If 1side of the breaker is kicked, It will run,but won't heat!!!! It is RARE that these dryers loose a heater or a thermostat!!!!
tshug
#6 Posted : Monday, March 16, 2009 6:00:03 AM(UTC)
tshug
I haven't had a chance to check the breakers yet since this washer/dryer is at our summer cottage. It'll be the first thing I do when I get there.
tshug
#7 Posted : Sunday, March 22, 2009 4:26:52 PM(UTC)
tshug
Drags1998, it did turn out to be the breaker that caused the problem. Even though it didn't appear to be tripped once I reset it the dryer did heat up. Thanks to you and denman for your responses.
khaos119
#8 Posted : Sunday, January 23, 2011 1:16:29 PM(UTC)
khaos119
Thanks guys, mine was not producing heat, but still drying clothes. Flipped breaker and it worked!! :)
