briang
#1 Posted : Wednesday, September 10, 2008 9:15:55 AM(UTC)
briang
My dryer does not spin when the start button is pushed. I took the back panel off and could see that the heating element was on but the drum does not spin. I replaced the motor and it still does not spin. Any suggestions on what to look at next?
Thanks.
libertyappl
#2 Posted : Wednesday, September 10, 2008 9:19:15 AM(UTC)
libertyappl
did you check the belt to make sure it was installed correctly?
Nat
briang
#3 Posted : Wednesday, September 10, 2008 9:25:08 AM(UTC)
briang
Yes, the belt was installed correctly
libertyappl
#4 Posted : Wednesday, September 10, 2008 9:29:31 AM(UTC)
libertyappl
Locate your wiring diagram and check the wires in the harness make sure they have good connections and no broken wires.
Nat
Drags1998
#5 Posted : Wednesday, September 10, 2008 2:24:21 PM(UTC)
Drags1998
If the motor IS running, and the belt is installed correctly, The drum HAS to turn!!!!
briang
#6 Posted : Wednesday, September 10, 2008 2:36:00 PM(UTC)
briang
Both the drum and the motor are not turning.
libertyappl
#7 Posted : Wednesday, September 10, 2008 2:39:33 PM(UTC)
libertyappl
Check your connections on the motor. Connection is either loose or somehow bad. Test the motor to see if it is good, you can ohm it out or you can use the belt and manually spin the shaft and listen for the clicking, if it doesn't spin freely or no clicking then the motor isn't any good.
Nat
Drags1998
#8 Posted : Wednesday, September 10, 2008 2:45:51 PM(UTC)
Drags1998
If the heat is on and the motor not running, Either the heater is SHORTED TO GROUND or the motor switch is STUCK!!! PS Check to see if you have 220V to the dryer, The heater will not come on unless the motor is running, Double check the heater for a short to ground
