needzumhelp
#1 Posted : Wednesday, September 10, 2008 6:13:29 AM(UTC)
needzumhelp
Gas was turned off and dryer was used , turned gas back on now dryer will run but there is no heat. What is the sequence of operation ? I belive the igniter is dead and therfore will not allow the gas valve to open . Igniter part #ap2042786, also can I test this igniter by putting 110v to it ,and should it glow ?
libertyappl
#2 Posted : Wednesday, September 10, 2008 7:51:23 AM(UTC)
libertyappl
You should test the ignitor with an ohm meter.
Nat
needzumhelp
#3 Posted : Wednesday, September 10, 2008 8:49:23 AM(UTC)
needzumhelp
Thank you for your responce i will do the check.
libertyappl
#4 Posted : Wednesday, September 10, 2008 8:56:29 AM(UTC)
libertyappl
Let us know what you find
Nat
Guest (4)
