The outer glass on the oven door was shattered and I have the new part. I need step by step instructions in putting it back on. Can I put it on the front with out removing door or at least without taking it apart? Does the outerglass end up on the outside of the side trim? How are the glass clips used? Thanks :confused:
You have to remove the whole door and take it all apart. If in doubt call a tech and have them install, shouldn't take a cerrtified tech over 45 min to do that job. Nat
