MChef 9824XPB
#1 Posted : Tuesday, January 18, 2011 10:05:04 AM(UTC)
MChef 9824XPB
  • Am replacing upper oven T-stat AP4101800 and need wiring info. PLEASE HELP!
#2 Posted : Tuesday, January 18, 2011 12:16:29 PM(UTC)
The wiring diagrams for this model in not available on line due to its age.
What happen to the old thermostat and why you can not just switch the wires from the old thermostat to the new one?
Are the terminals on the new thermostat marked?
How many wires was connected to the old thermostat?
MChef 9824XPB
#3 Posted : Tuesday, January 18, 2011 7:09:14 PM(UTC)
MChef 9824XPB
Old Tstat mechanically failed making broiler operation hit-&-miss.
My connection notes made during removal are incomplete and suspect.
New Tstat has same terminals as old and are:
7 C
1 2
5 6
9 BA BR
There was a jumper connecting 5 & C (I think)
1 & 2 should be power and were White wire & Red wire (I think)
7 had a White doubled with another White (I think)
9, BA & BR side had the remaining White(s) [and perhaps a Black] wires connected but I don't know to which terminal(s)
Tstat was too expensive to burn up with incorrect wiring.
Gene, Can you save me???
#4 Posted : Wednesday, January 19, 2011 12:35:11 PM(UTC)
Can you trace each of the wires to find exactly where it goes and post the results?
Some of the wires can have two colors. As the example: the white wire with the red strip - WH/R.
MChef 9824XPB
#5 Posted : Friday, January 21, 2011 1:20:26 PM(UTC)
MChef 9824XPB
I can trace wires.
I am so far into this thing I need a wiring diagram. If you don't have one, do you know where I can get one?
Thanks,
#6 Posted : Friday, January 21, 2011 4:07:09 PM(UTC)
The only way to get the diagram is to call Magic Chef.
