Floyd Mooneyham
#1 Posted : Thursday, July 16, 2009 7:48:06 AM(UTC)
Floyd Mooneyham
How do you test to see if it is functioning properly?:confused:
#2 Posted : Thursday, July 16, 2009 4:43:28 PM(UTC)
What is the exact problem?
What is the complete model number of the refrigerator?
ngoc101
#3 Posted : Monday, January 17, 2011 7:24:42 PM(UTC)
ngoc101
Refrigertor #ED22QFXHW00 Whirpool Ref.
Water inlet valve #2304833
Same the question ,How I test water inlet valve work or not
. The water cannot pump into ice maker ? It's problem water inlet valve ?
#4 Posted : Monday, January 17, 2011 7:40:01 PM(UTC)
Swap the wires between the red and green solenoid. Push the water release lever on the water dispenser for a few seconds. Check if there is water in the ice maker.
If there is no water, check the water fill tube which comes into the ice maker.
If the fill tube is clear, replace the water inlet valve.
- The water inlet valve Part number: AP3160649
ngoc101
#5 Posted : Tuesday, January 18, 2011 12:41:20 PM(UTC)
ngoc101
Yes I swap the wire but the connetcor from green not fix with conector from red solenoid then i conect by wire then the water leak on floor . do you think solenoid not working ?
#6 Posted : Tuesday, January 18, 2011 1:04:20 PM(UTC)
Originally Posted by: ngoc101 Go to Quoted Post
...then i conect by wire then the water leak on floor ...
Can you describe it more detailed?
ngoc101
#7 Posted : Wednesday, January 19, 2011 8:26:13 AM(UTC)
ngoc101
That mean I swap the wires betwen red and green but the conector from green wire not fix with the pin of red solenoid ( the pin from red biger ,see the picture )But I still conect by wires, then the water leak on floor from the tube of red solenoid . UserPostedImagesee
#8 Posted : Wednesday, January 19, 2011 12:51:28 PM(UTC)
Is this tube broken?
Did you check the water fill tube which goes into the ice maker? Sounds like it is blocked.
ngoc101
#9 Posted : Wednesday, January 19, 2011 7:11:58 PM(UTC)
ngoc101
The tube is ok .the tube from red solenoid go into ice maker, I didn't hear nothing .How you check solenoid( green and red one ) still working ? like test by the meter , think the red solenoid is bad ?
ngoc101
#10 Posted : Saturday, January 22, 2011 6:27:32 AM(UTC)
ngoc101
Can you give me the idea ? You think I need replace the water inlet valve and order the new one?
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 4/27/2024 6:55:56 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
Water inlet valves burning out (Dishwasher Repair)
by Tydinelle 3/3/2024 4:06:06 PM(UTC)
Frigidaire dishwasher 2nd water inlet valve fails (Dishwasher Repair)
by Guest 2/13/2024 3:32:15 AM(UTC)
Whirlpool Water Inlet Valve Repair for Leak (Refrigerator & Freezer Repair)
by ForumUser1 12/23/2023 12:57:44 PM(UTC)
Water Inlet Valve WR57X10033 / AP3189335 for General Electric DTL18ICSRRBS (Refrigerator & Freezer Repair)
by breckrider 1/18/2023 7:43:17 PM(UTC)
Replaced water inlet valve, still no ice or water (Refrigerator & Freezer Repair)
by Guest 7/3/2021 3:14:08 PM(UTC)
dishwasher not filling with water...already changed water inlet valve (Dishwasher Repair)
by jbonez 5/25/2021 5:32:22 PM(UTC)
Leaky new water inlet valve on whirlpool gold refrigerator (Refrigerator & Freezer Repair)
by Guest 4/4/2021 5:35:03 PM(UTC)
Water Inlet Valve for Whirlpool WRF560SEYW05 (Refrigerator & Freezer Repair)
by nycgene 7/30/2020 10:50:55 AM(UTC)
Noise after water inlet valve replacement (Refrigerator & Freezer Repair)
by Kristsivia 11/3/2019 4:29:36 PM(UTC)
GE washer replace WH13X10057 water inlet valve (Washer Repair)
by Cmath 3/9/2017 9:23:21 AM(UTC)
Water inlet valve (Washer Repair)
by dcbradt 3/8/2017 4:02:37 AM(UTC)
Water inlet valve leaking (Washer Repair)
by Jimh64 1/29/2016 7:31:50 AM(UTC)
Hot to replace water inlet valve on GE washer dryer combo WSM2700HCWWW? (Washer Repair)
by AbbyBrickman 1/4/2016 8:36:24 PM(UTC)
