I have an 8 year old Frigidaire stove whose oven came on one night and would not turn off.
Pushing the clear/off button has no effect. Also tried setting oven timer and that does not turn it off. It is the bottom oven element only, and it goes red hot. The oven need to be unplugged or oven element stays on high.
I took off the rear panel and looked at connections, all are fine. Also looked at temperature probe and it looked okay. All other functions on the stove operate properly (burners, broiler, clock and timer)
Is this a failed Electronic Oven Control? Any other diagnostics I can try before ordering an expensive electronic part that will probably not be returnable if that unit is not the culprit?
THIS FORUM IS DEAD!!!!!!! |
