taf
#1 Posted : Monday, September 8, 2008 9:21:42 AM(UTC)
taf
#1 problem is the refrigerator is not staying cold, the freezer works fine. Water drips periodicly from the temperature controller located at the back wall of top shelf area.
#2 Posted : Monday, September 8, 2008 1:45:28 PM(UTC)
Most likely the problem is a clogged and/or frozen drain. The model number you posted does not come up.
taf
#3 Posted : Monday, September 8, 2008 8:23:56 PM(UTC)
taf
Thank you Gene,
I have the correct model number . FRT18B4AW6. I'm trying to locate a diagram of my model refrigerator so I can see where the clogged drain may be. tks again
taf
#4 Posted : Tuesday, September 9, 2008 10:18:21 AM(UTC)
Remove the rear cover inside the freezer and you'll see the drain pan (#17 on the break down diagram) with the drain hole under the evaporator (#15 on the break down diagram).
Use a hair dryer and/or a turkey baster with hot water to defrost and clean it.
