2 Pages<12
EDDEE
#11 Posted : 14 years ago
EDDEE
What is the difference between the actual and set temperatures?
Similar problem. Oven worked fine for years and now it takes a while to light when turned on or will not relight after being on. I have changed the gas valve and thermostat already. This oven uses a hot surface igniter which is glowing bright as soon as I turn the oven on. You don't think its the hole thing?
#12 Posted : 14 years ago
Even if the igniter does glow it still can be bad if it's not draw enough current to open the gas valve. This is very common situation.
If you do need the correct part number for the oven igniter, post the complete model number of the oven.
madmaxltd
#13 Posted : 14 years ago
madmaxltd
Another year went by after drilling the holes. It would try to light, but the burner would not fully ignite. I probed the gas inlet, where the burner connects, with a needle and now it works much better.
EDDEE
#14 Posted : 14 years ago
EDDEE
After reading a thread on how the gas valve control responds to the voltage reading generated from the ignitor it was clear that that was where the problem lay! I have already installed the new ignitor and we're good to go! thanks for the response.
Ed
Guest
#15 Posted : 3 years ago
Guest
Rank: Guest
United States
I am model 505m0bb1 and it’s doing the same thing 5 years old can you give me a part number
Kenmore Elite Gas Oven Won't Stay Lit (Oven Repair (including Ranges and Cooktops))
by gershon 15 years ago
2 Pages<12
