Derrick Cote
#1 Posted : Monday, September 8, 2008 5:46:52 PM(UTC)
Derrick Cote
My problem is the same (I believe) as the thread:
http://forum.appliancepartspros...11518-f1-error-code.html
Can you provide me with a part number (black) and I'll happily order through you guys!
The panel (LEDs) have been hard to read for a while and became increasingly problematic until now it is totally unrecoverable. Will replacing the membrane pad also likely fix the LED display?
Thanks,
Derrick
libertyappl
#2 Posted : Monday, September 8, 2008 6:46:26 PM(UTC)
libertyappl
I doubt that the keypad being replaced will help what your issue. By your model number your part should be AP172494.
Nat
Derrick Cote
#3 Posted : Tuesday, September 9, 2008 12:12:04 PM(UTC)
Derrick Cote
So the other threads on this site seem to suggest that the membrane switch is shorted and needs replacing to fix the F1. Why do you not think that will help me? Or are you saying that you don't think the membrane pad will help my display?
Derrick Cote
#4 Posted : Tuesday, September 9, 2008 12:13:57 PM(UTC)
Derrick Cote
Also, the part number below is for the ERC. What is the part number for the membrane pad?
Thanks!
Derrick
libertyappl
#5 Posted : Tuesday, September 9, 2008 12:17:28 PM(UTC)
libertyappl
The membrane pad will not help the display, that is control by the board. Check your connections first though, noticed on several that we have done that they get corrodid, which causes the same problem as if the control board was out. I like to use the KISS rule first before buying expensive parts.
Nat
Derrick Cote
#6 Posted : Tuesday, September 9, 2008 12:29:49 PM(UTC)
Derrick Cote
OK thanks for the clarification! Do you agree that the membrane pad is required to fix the F1/beeping? What is the part number (black) for this Amana?
Thanks,
Derrick
libertyappl
#7 Posted : Tuesday, September 9, 2008 1:06:27 PM(UTC)
libertyappl
It is possible for the membrane to be part of the beeping issue (part# AP93441).
Nat
dperhase
#8 Posted : Thursday, September 25, 2008 7:30:51 AM(UTC)
dperhase
I have a Magic Chef Oven and the F1 code keeps beeping I saw that an oven sensor my be the problem. How much is an oven sensor I have a model no for my oven 3868XRW-X. Can you help me?
libertyappl
#9 Posted : Thursday, September 25, 2008 7:37:25 AM(UTC)
libertyappl
dperhase,
the oven sensor for your range is $32.58, part # AP204835 from this site.
Nat
lazermule
#10 Posted : Monday, October 6, 2008 3:27:43 PM(UTC)
lazermule
Nat
I have the same issue with my Amana ARTSC8651 with the continuous beeping. When it started beeping, it kept switching between the timer and the clock like someone was sitting there hitting the timer button, and finally it would show the F1 code. The oven cancel button would take it out of its fit for the moment but it would come back in a minute or less again doing the same thing. I pulled it apart, unhooked the membrane pad cable, gave it power and the beeping went away and of course only the cook top works for the moment. Does that sound like a membrane pad problem?
Lazermule
Guest (5)
