mikevanhal
#1 Posted : Thursday, February 14, 2008 1:30:10 PM(UTC)
mikevanhal
Hi. When I turn on my oven, it makes a clicking noise when it lights. Then, it'll light and shut off not even a minute later. I'll keep trying and it'll smell like gas.
Is it the igniter? What should I do?
Thanks!
#2 Posted : Friday, February 15, 2008 11:41:29 AM(UTC)
How long it takes to light up the burner since the control called for heat?
Also I need the complete model number of the unit.
gas4now
#3 Posted : Monday, September 8, 2008 12:06:58 PM(UTC)
gas4now
I have the same problem with a Magic Chef CGR3742AWD gas oven. The glow plug gets red, gas flows, the oven ignites, but then shuts off 10 seconds later. Then the oven begins a cycle of trying to ignite over and over, acting as if the flow of gas is restricted and never again fully lighting until it is turned off and given time to cool completely.
The broiler in the top of the oven works fine.
Thanks, KM
#4 Posted : Monday, September 8, 2008 2:30:00 PM(UTC)
KM,
Most likely the problem is a bad bake igniter.
- The part number for the igniter is AP205873
Here are the break down diagrams for the Magic Chef range Model CGR3742ADW
Frigidaire oven won't stay lit (Oven Repair (including Ranges and Cooktops))
by Guest 7/31/2022 6:36:11 PM(UTC)
Oven won't stay lit. (Oven Repair (including Ranges and Cooktops))
by simyri 10/14/2013 4:34:08 PM(UTC)
My oven won't stay lit with door closed (Oven Repair (including Ranges and Cooktops))
by MsDredd 11/17/2010 10:22:22 AM(UTC)
Oven won't stay lit (Oven Repair (including Ranges and Cooktops))
by MelvinG 11/4/2010 12:29:29 PM(UTC)
Oven won't stay lit and has gas smell (Oven Repair (including Ranges and Cooktops))
Belarus tertoyou 12/23/2009 6:03:29 AM(UTC)
Kenmore Elite Gas Oven Won't Stay Lit (Oven Repair (including Ranges and Cooktops))
by gershon 8/31/2009 7:23:32 AM(UTC)
Gas Oven won't stay lit (Oven Repair (including Ranges and Cooktops))
by janicet 3/25/2008 8:13:08 PM(UTC)
by donnalee115 11/26/2007 3:30:38 PM(UTC)
