philippcclark
#1 Posted : Thursday, January 13, 2011 8:49:37 AM(UTC)
philippcclark
one burner (the big one) on the stovetop is not sparking. it's getting gas (i can light it with a lighter) and it is clean, but no spark. the other three burners spark and light fine. any thoughts?
#2 Posted : Thursday, January 13, 2011 12:39:54 PM(UTC)
Can you hear the clicking sound when you turn this burner on?
Would this burner igniter spark if you turn on any other burner?
If the first answer is NO while the second is YES, then the problem is a bad ignition switch (#9 on the diagram) for this burner.
- The ignition switch Part number: AP2994649
philippcclark
#3 Posted : Thursday, January 13, 2011 3:15:11 PM(UTC)
philippcclark
no clicking sound from the burner, no spark at all, just gas. interestingly, i just cleaned it, and it sparked for a while, but kept sparking (along with the other three burners) even after lit. then it just stopped sparking (and clicking) altogether.
#4 Posted : Thursday, January 13, 2011 3:40:40 PM(UTC)
Sounds like the problem is a bad spark module (#1 on the diagram).
Make sure the ceramic part of the burner igniter is not damaged.
- The spark module Part number: AP2994560
Guest (4)
