8 Pages<12345>»
#21 Posted : Sunday, February 3, 2008 10:44:13 PM(UTC)
I'm glad you were able to fix it.
osgoodrp
#22 Posted : Monday, June 2, 2008 3:30:59 PM(UTC)
osgoodrp
Hi Gene,
I have a very similar issue with our advantium oven. Using the convection oven part and it just died in the middle of cooking. I found the diagram and it's the same as Nick's. My issue is how do I test the fuse (assuming I find it) and I can't see the diagrams linked to your post.
#23 Posted : Monday, June 2, 2008 7:15:34 PM(UTC)
Click on any diagram link on page 1 and type your model number in the search box. You'll get all break down diagrams.
After you locate the fuse just check it for continuity (remove the wires first).
osgoodrp
#24 Posted : Tuesday, June 3, 2008 3:55:33 PM(UTC)
osgoodrp
Thanks. Pulled the fuse and it's showing 0 on VOM, so I ordered the cavity thermocouple.
osgoodrp
#25 Posted : Thursday, June 5, 2008 11:47:40 AM(UTC)
osgoodrp
Got the part and installed it, we're back in business.
Many thanks from a greatful wife also.
#26 Posted : Thursday, June 5, 2008 12:41:29 PM(UTC)
FlockWSO
#27 Posted : Sunday, August 24, 2008 12:28:41 PM(UTC)
FlockWSO
I'm glad I found this forum! I also have a dead Kenmore Elite Advantium 120 - Model 363.63699301. I understand this model may be different than those already mentioned in this thread, but after looking at the diagrams they appear fairly similar.
Anyway, I was using the convection oven when it just stopped - no display, no light, nothing. The power going to the oven power cord checks ok, so the issue is within the unit.
Based on the previous repairs in this thread, it looks like I need to take the unit off the wall, check the fuse, and if the fuse is ok I should replace the themocoupler, right? Based on my parts list and diagrams, I see a "TCO, Oven Cavity" and a "TCO, Base Hood." Is the Oven Cavity the one I should repace? Is there a way to bench check a TCO? With a manual and some tools I am fairly handy with disassembly/assembly, but I can certainly use a primer on how the parts work together.
Any help is appreciated!
FlockWSO
#28 Posted : Sunday, September 7, 2008 3:23:59 PM(UTC)
FlockWSO
Well, even though I didn't get a reply here, I took the plunge and bought the TCO. Taking the oven off the wall and then tearing into it wasn't fun, but the "operation" was ultimately successful. There certainly were a lot of layers to disassemble to get to the part I needed to swap, but in the end it was pretty straight forward.
So thanks for the previous postings here - it gave me the confidence to perform this surgery on my own!
kenmoreuser1
#29 Posted : Monday, September 8, 2008 8:44:36 AM(UTC)
kenmoreuser1
You have been a member since:: 9/8/2008(UTC)
After reviewing all the issues here, it should steamline my troubleshooting. I'll post if it works.
Thanks All
Strummer
#30 Posted : Sunday, October 12, 2008 1:47:38 PM(UTC)
Strummer
I have the same issue, do I have to take it of the wall to check the fuse?
Guest (6)
8 Pages<12345>»
