Jlsowers
#1 Posted : Thursday, January 13, 2011 9:50:38 AM(UTC)
Jlsowers
Our dryer heats, but only keeps running on the regular setting. anything below this setting it turns off and says DRYER DOOR OPEN.. replaced the door switch.. still happening.. HELP.. have company and lots of laundry.. :confused: Julie
Jlsowers
#2 Posted : Thursday, January 13, 2011 10:12:32 AM(UTC)
Jlsowers
I can be reached at 920-621-0251
#3 Posted : Thursday, January 13, 2011 1:43:07 PM(UTC)
Julie,
What was the exact error code? "DRYER DOOR OPEN" is not a valid error code.
Jlsowers
#4 Posted : Friday, January 14, 2011 5:32:26 AM(UTC)
Jlsowers
It starts to run then stops and all it says in red is DRYER DOOR OPEN... No error codes unless AU is one... will not stay running in any cycle... but there is heat... could it be the timer.. I appreciate all your help...
Julie,
#5 Posted : Friday, January 14, 2011 3:37:26 PM(UTC)
Julie,
Perform the tests as described in the attached file and post the results.
File Attachment(s):
Amana dryer - Door open on display.doc (70kb) downloaded 25 time(s).
Jlsowers
#6 Posted : Friday, January 14, 2011 8:18:05 PM(UTC)
Jlsowers
The motor does start with the door closed.. but it only runs a minute or so and then stops and the door open lights up...
#7 Posted : Friday, January 14, 2011 8:37:48 PM(UTC)
You have to perform all the voltage and continuity tests form the flowchart.
Jlsowers
#8 Posted : Friday, January 14, 2011 9:02:57 PM(UTC)
Jlsowers
So noted. Will do later today. It is midnight here. If we have ? Do you have number to call.
Jlsowers
#9 Posted : Friday, January 14, 2011 9:04:18 PM(UTC)
Jlsowers
:) So noted. Will do later today. It is midnight here. If we have ? Do you have number to call. You can text me at above number with it. Thank you
Jlsowers
#10 Posted : Saturday, January 15, 2011 1:02:25 PM(UTC)
Jlsowers
