klplatt81
#1 Posted : Thursday, September 4, 2008 2:39:45 PM(UTC)
klplatt81
I just replaced the control board and panel. Seemed to be working fine until my wife turned both ovens on. About 2 seconds after she set the second oven and pressed start, all lights lit up and it displayed PF. One oven can be used without any problem but as soon as the other is started it goes to PF. Any ideas?
#2 Posted : Friday, September 5, 2008 2:45:26 PM(UTC)
Check the lower voltage transformer and how firm it is connected to the control board.
klplatt81
#3 Posted : Saturday, September 6, 2008 12:10:17 PM(UTC)
klplatt81
Thanks....I rechecked all connections. What is happening after playing with it for awhile is that the upper oven works fine. The lower oven works sometimes, but other times goes to PF within a second after hearing relays click. Both ovens together never work. Is it possible that I received a bad control board?
#4 Posted : Saturday, September 6, 2008 2:53:40 PM(UTC)
Unfortunately defective new parts do not surprise me anymore. You probably have to exchange the control board.
klplatt81
#5 Posted : Saturday, September 6, 2008 3:57:13 PM(UTC)
klplatt81
Thank you for taking the time to respond! I'll work on a replacement next week.
kevin
#6 Posted : Saturday, September 6, 2008 7:27:11 PM(UTC)
Keep us posted.
klplatt81
#7 Posted : Tuesday, September 30, 2008 1:51:52 PM(UTC)
klplatt81
I received a new control board, replaced it, and all is working fine! It was, in fact, a defective board.
Thanks again for your help!!
kevin
#8 Posted : Tuesday, September 30, 2008 6:02:08 PM(UTC)
You're welcome. I'm glad you finally fix it.
Guest (4)
