mario 61
#1 Posted : Friday, September 5, 2008 7:26:39 AM(UTC)
mario 61
Hello,
I have an interesting problem. My Maytag dryer is kicking off the Hi Temp sensor in the heating chamber. I have replaced the sensor with no success. When I bypass the sensor the dryer works great. The venting is very clear and open, but I notice the heating flame is very large and hitting the sensor bottom which triggers it off (as it should). Has anyone had experience with a gas valve failing in this manner. Thanks
#2 Posted : Saturday, September 6, 2008 6:05:11 AM(UTC)
The gas valve orifice determines the flame size. Either you have the wrong one, or the regulator has failed on your propane bottle.
mario 61
#3 Posted : Saturday, September 6, 2008 6:18:20 AM(UTC)
mario 61
Hello,
Thanks for getting back to me. The unit runs on natural gas and it is the original valve. Could the gas valve itself have a pressure issue. Thanks.
#4 Posted : Tuesday, September 9, 2008 12:59:45 AM(UTC)
I have never heard of a gas valve acting up like this, but it's worth a try, this site has good return policy.
Also, check the brass orifice on the gas valve, possibly someone cleaned it out and enlarged it. If so, just order a new one from this site.
Guest (4)
High flame in oven (Oven Repair (including Ranges and Cooktops))
by cstric1 12/6/2007 1:22:13 PM(UTC)
