My GE oven control/clock panel was beeping and turning the oven off and on. This went on for 6 months. Then one day the bake element burned in half and shot sparks every where. So, I replaced both with GE parts. The bake and broil did not work when put it all back together, about 20 mins later the bake element started working, then the broil as well. I turned the temp up and down, off and on, every thing was working perfectly. I tried it again this morning and again NOTHIng! I set the temp and I hear a click, temp shows 100 and never climbs. Please help me we have been with out a range for 4 weeks now and microwave dinners are getting very old. Thank you so much Mike Saylor.
Originally Posted by: Mike Saylor  My GE oven control/clock panel was beeping and turning the oven off and on. This went on for 6 months. Then one day the bake element burned in half and shot sparks every where. So, I replaced both with GE parts. The bake and broil did not work when put it all back together, about 20 mins later the bake element started working, then the broil as well. I turned the temp up and down, off and on, every thing was working perfectly. I tried it again this morning and again NOTHIng! I set the temp and I hear a click, temp shows 100 and never climbs. Please help me we have been with out a range for 4 weeks now and microwave dinners are getting very old. Thank you so much Mike Saylor. Answered here: http://forum.appliancepartspros...ase-help.html#post236566Gene.
Originally Posted by: Gene  I would recommend to replace the control board next. F3 & F5 error codes are absolutely not connected between each other and that makes the control board the first failure suspect. - The part number for the control board is AP3189149 Here are the break down diagrams for the GE oven Model JRS04BW2BBGene. HOW DO U WIRE OLD BOARD TO NEW
How Do U Wire Old Oven Control Up To New Oven Control Ap3189149
Marcus,
How the wires were connected to the old control board?
[the New Oven Control Has More Pronges On It Then The Old One It Has Where The Bake And Broil Opn Control And New One Has 3 Relays Old One Has 2 Relays
Once again: Quote:...How the wires were connected to the old control board?... Gene.
