cbelt
#1 Posted : Tuesday, January 4, 2011 5:00:58 PM(UTC)
cbelt
I am trying to replace my lid switch but unfortunately cannot figure out how to remove the control panel on my washer. It does have end caps but I can't seem to get them off and I don't see and screws that look to be holding it down either. Any advice?
sidfink43
#2 Posted : Thursday, January 6, 2011 6:05:40 PM(UTC)
sidfink43
The exploded diagram of your model shows they are held on by a screw in each one that you access from the back of the machine. Take a look and see if that is the case.
Removing control panel and installing new control board (Oven Repair (including Ranges and Cooktops))
by devronh 3/4/2014 6:27:03 AM(UTC)
Removing Control Panel Wall Oven (Oven Repair (including Ranges and Cooktops))
by Germanyjon 4/30/2013 6:45:26 AM(UTC)
Removing control panel (Washer Repair)
by Grady White 9/16/2012 8:20:11 AM(UTC)
Need help removing control panel and front panel to get at the drain pump (Washer Repair)
by jthenne 2/16/2011 11:43:38 AM(UTC)
Removing control panel (Oven Repair (including Ranges and Cooktops))
by mamacitizen 3/7/2010 3:58:18 PM(UTC)
Need guidance on removing control panel (Oven Repair (including Ranges and Cooktops))
by NCAmy 10/30/2009 1:59:29 PM(UTC)
