GWW-1
#1 Posted : Thursday, January 6, 2011 4:15:02 PM(UTC)
GWW-1
I have GE Triton XL Dishwasher Model # GSD6200JO1WW and I can not get the water to drain out of the basin. I believe the pump is broken as it was making a lot of noise prior to it quitting. What do you think?
Additionally, do I need to be using the large hard plastic drain hose that it came with? It is not very convenient were I had to use it last so I took it off.
Thank you,
GWW-1
Joe / APP Team
#2 Posted : Friday, January 7, 2011 1:54:06 PM(UTC)
Joe / APP Team
Thank you,
GWW-1
GWW,
You probably had a small piece of glass or debris in the drain pump and damaged the impeller, or motor windings.
Part number: AP3192221
As for the drain hose,
If it is not kinked or collapsing from the hot water, you can get by with the one you're using, but were it me, I'd replace it .
Good Luck,
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
GE Dishwasher GDF620HMJ2ES (Dishwasher Repair)
by lou@officenerd.com 1/14/2024 3:32:20 PM(UTC)
GSD5120D00BB GE dishwasher leaking at the bottom corners (Dishwasher Repair)
by ron Minervino 12/7/2023 9:15:11 AM(UTC)
GE Dishwasher Model GDT655SSJ2SS (Dishwasher Repair)
by Dan Jones 11/16/2023 11:33:43 AM(UTC)
GDF610PMJ5ES (GE Dishwasher) - No Power to LED Display (Dishwasher Repair)
by txwildcard 6/7/2023 2:40:51 PM(UTC)
GE dishwasher GDT580SSF5SS water doesn't get hot and dishes are not drying (Dishwasher Repair)
by jmbuffy 5/15/2023 4:45:57 PM(UTC)
GE Dishwasher Loads water but never agitates to clean dishes (Dishwasher Repair)
by Guest 4/19/2023 6:38:21 AM(UTC)
GE Dishwasher, Model: GDF530PGM0WW (Dishwasher Repair)
by Guest 4/12/2023 12:06:40 PM(UTC)
GE Dishwasher GSD900D-02 Door Gasket Gap (Dishwasher Repair)
by DJW000 2/5/2023 10:05:34 AM(UTC)
GE Dishwasher dead UI board (Dishwasher Repair)
by Guest 1/26/2023 9:44:03 PM(UTC)
GE dishwasher - general query about a ball at the back in the tube (Dishwasher Repair)
by delboy1881 7/27/2022 7:49:15 AM(UTC)
GE Dishwasher beeps every 10 seconds (Dishwasher Repair)
by bethH 7/12/2022 3:03:53 AM(UTC)
Ge dishwasher seal replacement (Dishwasher Repair)
by Guest 4/21/2022 5:34:16 AM(UTC)
GE Dishwasher - No Power - Replaced Control Board, Wiring Harnes, and UI Board (Dishwasher Repair)
by aervin 4/19/2022 7:32:28 AM(UTC)
GE dishwasher not filling and other problems (Dishwasher Repair)
by Guest 4/14/2022 3:40:35 PM(UTC)
