I have to replace the bearings on my GE Spacemaker Dryer Model DSXH47EG1WW. I have found the part on the website but are any additional parts recommended other than the bearing kit. Also, what is the order of steps to replace the bearings? Thanks.
You might want to replace the belt and pulley as long as you are taking it apart, and be sure you clean all the lint out of the internal air passges as it tends to build up in these models. Here is a link to the service manual for your machine (yes I know it says Frigidaire, you bought a Frigidaire even though it says GE). http://frigidaireservicetips.co...rGoodandBetterModels.pdf
