M.Watt
#1 Posted : Thursday, January 6, 2011 7:53:40 AM(UTC)
M.Watt
Maytag clothes washer - Model A208, SN# 347325 CV
Never a problem with this machine. Just packed it in. Cycle will start, tub will fill with water, then nothing. Slight burning smell when first happened. Lid switch checked, continuity in both directions. Can pull belts by hand, see motor turning. Belts look Ok, no bits of rubber evident. Some motor starter/capacitor piece attached directly to motor. Machine manufactored Nov. 79. Talk about not making them like they used to. Worth reparing? Appreciate any advice.
magician59
#2 Posted : Thursday, January 6, 2011 8:01:37 AM(UTC)
magician59
As long as it's still clean, with no chips out of the porceline, or rust, It is worth the fix. A common problem is "glazing" of the motor pulley. A replacement pulley, and new set of belts, fixes this. Also, while the belt is off the pump pulley, chsck to make sure you can spin the pump pulley by hand.
Part number: AP4289668
Whirlpool duet clothes washer (Washer Repair)
by DThiessen 9/28/2022 10:08:52 AM(UTC)
clothes washer don't work, troubleshooting manual wtw5500xw0 cabrio (Washer Repair)
by paulmars 4/2/2022 10:43:24 AM(UTC)
Kitchenaid clothes washer (Washer Repair)
by 76 Terra 1/24/2022 10:05:31 AM(UTC)
Clothes Washer (Washer Repair)
by jogrodz 4/2/2018 6:36:28 AM(UTC)
clothes washer only leaks when filling (Washer Repair)
by elijahfischer 8/22/2013 7:06:46 AM(UTC)
Maytag clothes washer (Washer Repair)
by fnolen 7/21/2013 3:04:54 PM(UTC)
Kitchenaid clothes washer won't spin without a push (Washer Repair)
by dlunde 5/29/2013 5:23:00 PM(UTC)
GE Clothes washer won't advance to wash cycle (Washer Repair)
by Zog 2/11/2013 4:33:01 PM(UTC)
by louis Dionise 12/14/2012 10:40:32 AM(UTC)
Clothes Washer Lint Issue (Washer Repair)
by kenmoregator 11/30/2012 3:01:10 AM(UTC)
by duffybpp 8/30/2012 3:28:44 AM(UTC)
Whirlpool Clothes Washer (Washer Repair)
by DirtyClothes1 7/7/2012 4:01:42 PM(UTC)
lint clothes washer (Washer Repair)
by paulmars 3/16/2012 4:21:12 PM(UTC)
Whirlpool Clothes Washer time won't advance (Washer Repair)
by djaco4749 3/9/2012 8:11:44 AM(UTC)
Clothes Washer won't spin clothes dry (Washer Repair)
by JCHD 1/26/2012 7:09:42 AM(UTC)
