2 Pages12>
darbar
#1 Posted : Wednesday, August 27, 2008 9:56:44 AM(UTC)
darbar
Views messages in topic : 7
the oven control panel is very din dose it need replacing or is it something else wrong
libertyappl
#2 Posted : Wednesday, August 27, 2008 10:19:23 AM(UTC)
libertyappl
Start with checking your voltage to the outlet. Is' it just the clock or the controls?
darbar
#3 Posted : Wednesday, August 27, 2008 12:29:46 PM(UTC)
darbar
The clock is brighter than the controls you can hardley see the controls or timer
#4 Posted : Friday, August 29, 2008 10:48:02 AM(UTC)
Most likely the problem is a bad EOC (aka clock).
- The part number for the EOC is AP367441
Here are the break down diagrams for the Jenn Air range Model SVE87600B
darbar
#5 Posted : Tuesday, September 2, 2008 2:08:19 PM(UTC)
darbar
Gene,
How hard is it to replace the EOC do you have to replace the membrance also. I had a repair man and he told me it would cost about
$ 600.00 for parts and labor.
Thanks Daryl
#6 Posted : Tuesday, September 2, 2008 4:49:00 PM(UTC)
Daryl,
I would start with the EOC and you can replace the membrane switch later, if needed.
You can find the complete instructions in the Service manual.
darbar
#7 Posted : Wednesday, September 3, 2008 9:12:26 AM(UTC)
darbar
Gene,
Dose the EOC control the oven because I don't think the oven heats up quite right and the broiler dose not work.
thanks
daryl
#8 Posted : Wednesday, September 3, 2008 1:32:24 PM(UTC)
Daryl,
The EOC does control the oven temperature and performance by reading the oven sensor and operating with the heating element(s).
darbar
#9 Posted : Wednesday, September 3, 2008 2:40:01 PM(UTC)
darbar
Gene,
Thank you for your time, the repair man said he needed to replace the touch control. Every thing else on the front panel works the burner work and light up. I wonder if this is realy needes to be done. Or is the EOC all it needs. Thanks again,
Daryl
#10 Posted : Wednesday, September 3, 2008 3:17:29 PM(UTC)
Daryl,
You can do what I recommended or you can follow your tech recommendation. If you'll follow my advise there is a chance to save some $$$$ (if you are going to DIY).
Jenn-Air Cook Top Gas Range JGC1526ADS15 (Oven Repair (including Ranges and Cooktops))
by patelvi 9/15/2021 1:11:05 PM(UTC)
Jenn-Air Cook Top Element Problem (Oven Repair (including Ranges and Cooktops))
by bmwed 3/16/2012 4:58:37 PM(UTC)
2 Pages12>
