Gene, thanks for quick response. I discovered I wasn't putting enough pressure on the hinge. A parts lookup revealed the pin hole, and sure enough when I used a HD screwdriver in the hinge slot guess what appeared. Now I won't go thru what I did. Thanks again.
My oven door will not stay shut. It will open just enough to release the switch showing that the door is not closed. My Modle # is RBS275PDQ8. I tried to dismantle the door but I am going into unchartered waters. Any info would help.
i think my oven door latch is broken since my door wont shut properly and i have order another one. can you tell me how to replace it...model KEBI171DWH10...i ordered part 4451896
cqwilliams, You have to open the control panel to access the door latch. Here are the break down diagrams for the Kitchen Aid oven Model KEBI171DWH10Gene.
