2 Pages<12
toastcoastie
#11 Posted : Saturday, August 16, 2008 4:14:22 PM(UTC)
toastcoastie
Gene, thanks for quick response. I discovered I wasn't putting enough pressure on the hinge. A parts lookup revealed the pin hole, and sure enough when I used a HD screwdriver in the hinge slot guess what appeared. Now I won't go thru what I did. Thanks again.
scott1301
#12 Posted : Sunday, August 17, 2008 6:28:20 AM(UTC)
scott1301
My oven door will not stay shut. It will open just enough to release the switch showing that the door is not closed. My Modle # is RBS275PDQ8. I tried to dismantle the door but I am going into unchartered waters. Any info would help.
#13 Posted : Monday, August 18, 2008 12:06:28 PM(UTC)
Hi Scott,
You can find the complete instructions in one of our previous posts: http://forum.appliancepartspros...ven-door-wont-close.html
- The part number for the oven door hinge is AP3046672
Here are the break down diagrams for the Whirlpool range Model RBS275PDQ8
cqwilliams
#14 Posted : Tuesday, September 2, 2008 11:59:04 AM(UTC)
cqwilliams
i think my oven door latch is broken since my door wont shut properly and i have order another one. can you tell me how to replace it...model KEBI171DWH10...i ordered part 4451896
#15 Posted : Tuesday, September 2, 2008 12:10:12 PM(UTC)
cqwilliams,
You have to open the control panel to access the door latch.
Here are the break down diagrams for the Kitchen Aid oven Model KEBI171DWH10
Oven door help? (Oven Repair (including Ranges and Cooktops))
by riki 1/13/2016 3:22:54 PM(UTC)
Oven door help (Oven Repair (including Ranges and Cooktops))
by labordec 1/5/2010 4:25:00 PM(UTC)
Whirlpool Oven Door Help (Oven Repair (including Ranges and Cooktops))
by RitaCStanley@aol.com 7/3/2009 4:40:03 PM(UTC)
oven door help (Oven Repair (including Ranges and Cooktops))
by marcue 1/9/2009 3:01:20 PM(UTC)
2 Pages<12
