66JohnWW
#1 Posted : Sunday, January 2, 2011 1:02:03 PM(UTC)
66JohnWW
Our 1999 Kenmore 25 cu/ft refrigerator stopped cooling/freezing all of a sudden. This is the first instance of any problem, since purchased new. Had not adjusted any controls in years. I did notice over several months that it was noisier when it was "running". The question is, should I call the Sears repairman or go buy a new one? I am not able to repair it myself, unless it's relatively minor.
#2 Posted : Monday, January 3, 2011 5:34:49 AM(UTC)
Need more info on what is happening.
What are the symptoms?
Is the compressor running?
Is the condenser/compressor fan running?
Is the evaporator (freezer) fan running?
Have you tried turning the temperature to off and then back to a cold setting?
66JohnWW
#3 Posted : Wednesday, January 12, 2011 8:58:27 AM(UTC)
66JohnWW
denman:
thanks for your questions; we decided to replace the unit with a new one.
Guest (4)
