My fridge stopped working. Found out that my Adaptive Defrost Board was bad. I bought a replacement board and plugged it in. I plugged in the outlet and the fridge started working. When I checked on the fridge 1/2 hour later, it stopped. The new Adaptive Defrost Board was burned on the same spot as the old board. I got another board, but don't want to plug it in yet. Any ideas as to what I should check next. Any help is appreciated. kenmore_no_more attached the following image(s):
I would check the defrost heater and the defrost thermostat.
Thanks. What should I look for in these two areas?
Originally Posted by: ApplianceJunk  I would check the defrost heater and the defrost thermostat. I can't seem to find these two items... help.
Originally Posted by: kenmore_no_more  I can't seem to find these two items... help. They are located in the freezer.
Originally Posted by: ApplianceJunk  They are located in the freezer. lol. thanks, I knew that. I appreciate the help. I'm a novice.... I don't think I'll be going any further. time to call in the calvery.
