slabman
#1 Posted : Sunday, August 31, 2008 8:57:58 PM(UTC)
slabman
My washer makes a grinding noise like maybe "sand" is in the impeller. It only seems to sound when the pump is engaged and now I see an error code which reads "not draining". Can I assume it is the pump that's bad? Where is this pump and how do I remove the panel to access?
ApplianceJunk
#2 Posted : Monday, September 1, 2008 5:37:46 AM(UTC)
ApplianceJunk
Here is the Service Repair Manual for your washer.
slabman
#3 Posted : Monday, September 1, 2008 6:31:37 AM(UTC)
slabman
Thanks, AJ. Do you agree that this grinding noise sounds like a bad impellor in the pump?
