guilty
#1 Posted : 14 years ago
guilty
Recently bought a house that has a 2004 Spacemaker XL1800 (Model: JVM1870BF02) microwave oven that has an inoperable glass turntable. I searched some of the older posts but mine doesn't "spin" freely as I have read. It turns in both directions but there is resistance in both.
Are parts readily available for this unit? What part of the drive mechanism is damaged? How can I restore the microwave to original operating condition?
Thanks in advance!
guilty
#2 Posted : 14 years ago
guilty
Any help here guys...?
guilty
#3 Posted : 14 years ago
guilty
One last bump...if not, guess I'm living with no turntable.
guilty
#4 Posted : 13 years ago
guilty
Any help out there?
Simon / APP Team
#5 Posted : 13 years ago
Simon / APP Team
Groups: APP Team
Hello.
You have to determine which part failed.
Take the bottom cover off, disconnect the plug from the turn table motor and using the multimeter check voltage stated on the name tag of the motor.
If there is no voltage - bad control board.
If you are reading voltage , check the motor for continuity.
No continuity - replace the motor.
Continuity present - take two screws out, drop the motor down and remove the coupler out (from inside the cavity).
If it's bad - replace it.
The turn table motor Part number: AP2024962
GE Spacemaker XL1800 (Microwave Repair)
by Dsteve 10 years ago
GE Spacemaker xl1800 vent fan not working (Microwave Repair)
by titannero 12 years ago
GE Spacemaker XL1800 - Making Buzzing Noise (Microwave Repair)
by bunk60 14 years ago
GE Spacemaker XL1800 running when you open door (Microwave Repair)
by andreah 14 years ago
by Louisle16 14 years ago
GE Spacemaker XL1800 won't heat (Microwave Repair)
by doanhtran@gmail.com 14 years ago
by sman2626 14 years ago
Ge spacemaker xl1800, Fan motor, light and table not working (Microwave Repair)
by mdorsey 14 years ago
GE Spacemaker XL1800 hum/buzz noise but heating works (Microwave Repair)
by faraday 16 years ago
GE Spacemaker XL1800 control panels locks up (Microwave Repair)
by usd777 16 years ago
GE Spacemaker XL1800 will only heat when vent fan is on (Microwave Repair)
by melissams17 16 years ago
GE Spacemaker XL1800 microwave making fluttering sound on startup (Microwave Repair)
by madhuvan 16 years ago
by gotkwah 16 years ago
GE Spacemaker XL1800 stopped heating and awful smell (Microwave Repair)
by perplexed 17 years ago
