LBsr
#1 Posted : Thursday, December 30, 2010 11:38:40 AM(UTC)
LBsr
It looks like the damper door stays wide open. Freezer side appears to work as it should. Water filter assembly froze and cracked. I replaced the water filter assembly and it is working. If I leave the thermostat settings to factory default, the frigerator side starts freezing.
How do I troubleshoot the the damper? I don't know if the thermostat is bad or the damper control assembly (or what??).
#2 Posted : Friday, December 31, 2010 9:13:44 AM(UTC)
Replacement parts for FRIGIDAIRE FRS23R4CW0 Frigidaire/refrigerator | AppliancePartsPros.com
Here is the tech sheet for this unit
http://manuals.frigidaire.com/p...f/Anderson/240389610.pdf
Here is a manual not sure if it covers your exavy unit but it6 does have a good section on the damper and it's control.
http://frigidaireservicetips.com/pdfs/495_2.pdf
LBsr
#3 Posted : Saturday, January 1, 2011 7:57:54 AM(UTC)
LBsr
Thanks. I believe the temperature control (refrig) or the damper assembly is bad. Both parts are over $100 and I don't want to guess at which one is bad. Can you tell me how to test the temperature control? Since the damper assembly is opening and closing, I suspect the temp control assembly is the problem.
