TemeculaDoug
#1 Posted : Saturday, August 30, 2008 10:04:19 AM(UTC)
TemeculaDoug
Hi all new here- had an issue where our oven just failed to get hot. Did a BUNCH of research, talked to techs and they all came to conclusion that igniter was bad. Bought igniter yestrday to the tune of $50, replaced this a.m. and same thing. oh yeah broiler works and ignites just fine.
Oven now goes to 159* (before it stopped at 100* on LCD)
and Im bummed and confused??!!
What next? Do I need a thermostat, a board?
This is going to get expesnive if I cant nail it down. I do have a ohmmeter if needed.
Do I need to leave the bottom of oven off to see if igniter is glowing or getting hot?
My wife wants to cook again,
thanks
Doug
abadfish66
#2 Posted : Saturday, August 30, 2008 11:05:12 AM(UTC)
abadfish66
Get your ohm meter, and check the resistance of the glowbar (ignitor) you just replaced. Should read between 50-150 ohms. Post results
TemeculaDoug
#3 Posted : Saturday, August 30, 2008 12:39:02 PM(UTC)
TemeculaDoug
do I need the oven set to ON and where do I want to probe / check on the igniter? there arent really any connecters on it (just spliced new one in with the ceramic wire nuts)
UserPostedImage
PS >>the NEW igniter is a (pt # AR404 on the box) hopefully this is correct?
thanks,
Doug
abadfish66
#4 Posted : Saturday, August 30, 2008 1:21:55 PM(UTC)
abadfish66
Take off the wire nuts and disconnect the wires and take an ohm reading from the bare wire ends of the ignitor.
abadfish66
#5 Posted : Saturday, August 30, 2008 1:24:58 PM(UTC)
abadfish66
That part is fine, they only make 2 kinds round and square, so if you took out a round ignitor, you replace it with a round ignitor.
TemeculaDoug
#6 Posted : Saturday, August 30, 2008 1:56:33 PM(UTC)
TemeculaDoug
10-4 let me give u an update soon on the vlt readings
I was going to swap the known good broiler igniter(same) except there is ALOT more dismantling to do so I said scr**w it.
abadfish66
#7 Posted : Saturday, August 30, 2008 2:06:44 PM(UTC)
abadfish66
ok, make sure it's an ohm reading and not a volt reading :)
TemeculaDoug
#8 Posted : Monday, September 1, 2008 8:33:58 AM(UTC)
TemeculaDoug
after checking further with the lower drawer pulled out, I found that the other wire conected to the gas valve (from the old connecteion at the igniter) had a tear in the sheath and caused it to short. After re-soldering and heatshrink, the oven fired right up. Apparently it had rubbed on the rearsheetmetal and torn the shething of the wire.
thanks for all the help abadfish66...
abadfish66
#9 Posted : Monday, September 1, 2008 8:35:07 AM(UTC)
abadfish66
no problem.
Guest (4)
