jsbraaten
#1 Posted : Wednesday, December 29, 2010 4:21:18 PM(UTC)
jsbraaten
I just got an older dryer and have to switch the cord to a 4 prong cord. I have looked up how to do this, but my dryer has no bonding strap, and the white cord that is supposed to be attached to a green screw is a green wire. Do I leave that wire attached and also connect the green wire from the cord to it as well? Or do I detach the green wire from the dryer from the screw and cap it? Thanks for any help you can give!
kayakcrzy
#2 Posted : Wednesday, December 29, 2010 4:24:54 PM(UTC)
kayakcrzy
Red goes on one end of the terminal block, and black goes on the other, and whit goes in the middle, and green has to go on a ground terminal. If not one there, cut if off, and tape it up, and you have it. Tom ApplianceEducator.com
jsbraaten
#3 Posted : Thursday, December 30, 2010 6:49:00 AM(UTC)
jsbraaten
Ok so, I got the wire thing figured out, but now the screws wont tighten. They were the exact same screws I just took off the last cord, but they are just hanging there no matter how much I tighten them. It looks like a nut is loose just behind the metal connecting part on the dryer. Frustrated!
kayakcrzy
#4 Posted : Friday, December 31, 2010 4:34:12 AM(UTC)
kayakcrzy
You basically have to pull the nut forward, when you are ready to screw the screw in. Tom ApplianceEducator.com
Guest (4)
