Oven cuts off 200 degrees prior to desired temperature. I have relpaced glow coil igniter and thermostat, however this has not fixed the problem.What can I do now?
Hi Bruce,
What is the complete model number of the oven?
Gene,Thanks for the reply. The :o Model # CPG9841 W689DQ
Originally Posted by: Bruce Hathaway  ... I have replaced glow coil igniter and thermostat... Hi Bruce, Which part did you call "thermostat"? What is the reference number for this part on the break down diagram? Did you check the oven sensor resistance? It suppose to be about 100 Ohms at the room temperature. Here are the break down diagrams for the Hardwick range Model CPG9841W689DQGene.
