The Washing Machine Will Not Spin Or Drain. It Fills Up And Agitates Just Fine. I Took Off The Drain Hose And It Was Not Clogged. The Washer Worked The Time Before With No Problem. I Hope You Can Give Me Some Suggestions To Fix This. Thanks, Bruce
