Clifton Addison
#1 Posted : Friday, August 29, 2008 8:23:39 AM(UTC)
Clifton Addison
My Kitchen Aid garbage disposer does not come on. I pushed the reset breaker button on the side of the motor, but nothing happens. can this be fixed, or do I need to purchase another one?
abadfish66
#2 Posted : Friday, August 29, 2008 8:52:22 AM(UTC)
abadfish66
luvz2flyalot
#3 Posted : Saturday, September 6, 2008 10:50:29 AM(UTC)
luvz2flyalot
If you hear humming with the switch on the thing is probably siezed by junk in the cutter. If so, insert the proper size allen wrench in the bottom center of the disposer and turn it one way or the other to see if you can free it. If no motor hum, check that circuit breaker in the household electrical panel hasn't tripped.
Guest (4)
Leaking Garbage Disposer (Garbage Disposer Repair)
by ebdunn 9/27/2011 9:44:48 AM(UTC)
Garbage Disposer Turn Off (Garbage Disposer Repair)
by baldridge 2/14/2011 4:52:12 AM(UTC)
garbage disposer (Dishwasher Repair)
by ish2008 10/14/2010 8:39:44 AM(UTC)
GE garbage disposer not working (Garbage Disposer Repair)
by jdgolf 12/25/2009 7:48:18 AM(UTC)
Ge Garbage Disposer (Garbage Disposer Repair)
by MILLERHOME 12/21/2008 6:08:46 PM(UTC)
by Clifton Addison 8/29/2008 8:32:54 AM(UTC)
Garbage disposer (Garbage Disposer Repair)
by bstoffel 7/22/2008 4:46:40 PM(UTC)
garbage disposer hums and no longer works (Garbage Disposer Repair)
by blawden 5/1/2008 12:30:48 PM(UTC)
Garbage Disposer leaks (Garbage Disposer Repair)
by papasmurf 1/2/2008 2:22:53 PM(UTC)
