mlac04
#1 Posted : Monday, December 27, 2010 7:22:49 AM(UTC)
mlac04
I have an the Amana LGA30AW dryer running on propane. All has been fine with this but last night it just stopped heating. I read articles and decided to check. I unplugged, removed the front panel and cleaned out the excess dust and lint. I plugged it back in and watched as I turned it on...the ignitor glows and ignites, the flames continue to burn, don't appear to be short cycling. The interior got very hot so thought I was good. However, when I replaced the front panel and loaded with damp clothes, no heat again. What could be wrong?
Joe / APP Team
#2 Posted : Tuesday, December 28, 2010 7:05:48 AM(UTC)
Joe / APP Team
Mlac,
Based on your description,
You either have a gas flow problem to the unit, or a bad set of gas valve coils,
Part number: AP3094251
The coils are the most likely problem, and a somewhat easy repair.
Remove power to the dryer,
Remove the front panel,
Disconnect the wire harness from the coils,
Remove the 2 screws holding the coil retainer bracket from the top of the gas valve,
Repalce 1 coil at a time, and make sure the stainless steel sleave remains on the split coil plunger assembly.
Reverse the procedure, and test the dryer for heat/ ignition.
Good Luck,
