Hi, I have a Maytag slide in electric range model MES5752BAB. The Right front/rear indicator light stays on even when the switch is off and the hot surface indicator light also stays on. My first thought was the control panel circuit board but I've read a few posts for similar problems and it looks like it might be something under the glass surface. Thanks for your help.
Read more: http://forum.appliancepartspros...post320878#ixzz18xEhV7qe http://forum.appliancepartspros.com
Has this post been read yet?
