jrnorris
#1 Posted : Tuesday, December 21, 2010 5:54:41 PM(UTC)
jrnorris
The auger on my Maytag washer floats off the base when it starts agitating. I can push it down but it come right back up. Do I need to replace the auger or the base, or both? Thanks for any help.
Robbie
#2 Posted : Wednesday, December 22, 2010 4:47:29 AM(UTC)
Here is the parts breakdown.
Replacement parts for MAYTAG PAV3300AWW WASHER-TOP LOADING | AppliancePartsPros.com
There should be a bolt holding it down, see Item 4 in Section 9.
jrnorris
#3 Posted : Wednesday, December 22, 2010 5:00:58 AM(UTC)
jrnorris
I believe what has happened is the auger has come off the post. I see the bolt but it's down inside a post. I'm not sure how to get to it to get it off. Any suggestions?
#4 Posted : Wednesday, December 22, 2010 10:14:39 AM(UTC)
Would a socket and an extension do the job.
tehahn1
#5 Posted : Tuesday, July 9, 2013 8:34:55 PM(UTC)
tehahn1
Robbie
I had the same exact problem. We always have used a "Softener Ball" and just dropped the ball in the washer. On the top of the agitator where the Fabric Dispenser is. ...it says: "Fill to line with water. Add cap full of softener".
So we tried it. Filled the fabric dispenser with water, and a cap full of softener. And the agitator didn't float when the water filled at high level. And we added clothes like we usually do. It bobbed just a little bit when agitating in the wash cycle... but it kept it from floating so high it didn't agitate. Saved me $60 for another agitator.
unlandano
#6 Posted : Wednesday, July 10, 2013 3:01:11 AM(UTC)
unlandano
Groups: Banned Users
